FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
So it is almost cold enough here to worry about winterizing. I have already unscrewed the blue plugs in the manifolds to drain the water out. I was wondering if this was good enough or should I run some pink stuff through the motor as well.
Motor and outdrive must also be empty. Like AD said, everything according to the book. If the motor, manifolds, water pump, oil cooler and outdrive are dry, no need to antifreeze. To do the outdrive, lower it down as far as it will go on the trailer and probe the drain holes on the lower part to make sure they aren't plugged up. Water in the outdrive will freeze and split the drive case.
Being a 2005 and your first post I'm thinking you have the 7 point drain and not the 3 point
It brings up more questions like its probably MPI, and which a serial number would help
You may have a blue plug on the circulating water pump hose, and if so no need to remove hose, just remove plug.
If MPI it would also have a blue plug just infront of the cool fuel on lower port side hose
