Pivot Pin 9.5 hp Johnson
Bream Killer
Well that's a fine mess I got myself into. I stripped the head on the pivot pin and then the easy out broke off trying to extract it. My question is since it's in there really good, do I need to take it out? I have a seal kit on the way and I was hoping to put a new washer on it. Do I need to drill it out or leave it?
Use a wee centerpunch or chisel and a small hammer to get it to turn.-----And invest in one of those impact screwdrivers if you are going to work on some outboard motors.
Bream Killer
With that thing snapping off the easy out do you really think I'll be able to get it to turn?
Remove the lower unit.----Remove the skeg on the lower unit.-----Shift rod will now come out with it.----Might be able to see what is going on now.
F_R
There, folks, goes another Easy-Out casualty There is no such thing. It ain't easy and it won't get it out.
Bream Killer
Yeah, I've had it all apart cause I wanted to put in all new seals. On the easy out, I guess it was the last resort so to speak. I'll work with the chisel and punch and let you know how it goes.
Bream Killer
SUCCESS!!! Man, I sure appreciate the help and patience you two. Pics to show the story. After drilling the easy out out I used the punch and chisel. I got a groove chiseled and then hammered it loose. Thanks again guys. I was sweating it.
Has that skeg been welded ?-----What does the bearing surface on the driveshaft look like ?----Above the spline on the driveshaft.-----Bushing above the pinion, what does it look like ?----Pictures needed.
Bream Killer
Here are the housings, I'll get pics of the gears ,bushings and shafts tomorrow. I have them soaking in varsol. I am going to run a tap thru the screw holes and wire wheel the housings for clean up. I took off the flywheel and checked gap on the points and all looks good there. I'd say the points are 8-10 years old but probably 20 hours run time. Also, it ran really good the other day after the carb rebuild. I had to take the flywheel off to get the tiller handle off and check the fuel connection. I'm replacing the fuel line. Lots of old grease build up so cleaning all of that in the tiller handle.
oldboat1
Do a pressure and vacuum test of the l.u. -- appears to be a weld, and will want to be sure it's holding.
I am pretty sure where that skeg and gearcase would go if it was my motor !!-----Scrap bin.------Of course I have no issues finding a good replacement for that mess.
Bream Killer
Where can I get a replacement?
A competing website to this has 1 listed in stock.----A mere $80 for factory new.
oldboat1
Less than an hour shop labor, btw. (With some searching, you might also be able to find a cheap 9.5 with a bad powerhead.)
jimmbo
For $80, I would waste another Second on the current Housing
If you could walk over to my shop I have a bunch of them on hand as well.-----But I think you are likely too far , far away.
Bream Killer
Yep, I haven't been to Canada since the 60's and I don't see myself going there anytime soon.
