holorinhal
Thread starter- Joined
- May 26, 2009
- 119
Ok so, back in march we were at the river. Boat ran great all day long. Got back to beach and hung out for a few hours and when we went to start up to pit on the trailer, engine wouldn't bump over. Just clunk, clunk, like starter went bad. So i have asumed that bad starter. Ordered new starter.
yesterday, finally got time to take a look and tried to turn it over. At first, it did the same clunk, but then it started to turn over rough and kept trying and it started turning and sputtering like it wanted to start. Finally it started turning and fired up. After it fired up it was running fine.
tan for about 5-10 minutes. Great oil pressure temp good for hose.
decided to check oil and uhoh, milky oil.
The oil is milky but oil level is not over full, so not enough to raise oil level.
i pulled all the plugs, no water in any cylinders.
i did a compression test on all cylinders and compression was 135-150 on all cylinders except #5.
cylinder #5 was 65 psi.
In addition, i found yesterday that one of my internal exhaust tip flappers was stuck shut. Dont know how long it was stuck.
I have EMI Thunder, through hull exhaust manifolds and SS risers.
Could the stuck flapper have backed up water and got sucked in through the exhaust valve and got past rings in low cylinder.
My next step is to leak down that cylinder #5
