holorinhal
Thread starter- Joined
- May 26, 2009
- 119
Do you store in the water or trailer?
Oh and no i dont store in water. I store on the trailer at my shop.
Before you take it apart why not do a cooling system Aire pressure test; it will tell you some of what you want to know. You know you have a stuck valve (water intrusion can cause this due to corrosion of the valve stems). But you don’t know where the water came from. You said you saw signs of water leaking on the outside of the mani/elbow joint but did you see any rust on the inside of the manifold runners that mate up with the exhaust ports? Any rust on the exhaust valves or ports when you pulled the manifold?
pS you can r&r the heads with the engine in the boat pretty easily if you have decent access; I did mine that way...
As far as sources of water, there are many, could be a crack in a cyl head, leaking HG, or even a rotted intake although that usually puts water in the cam valley and in the oil.
I just recently got time to get back to trying to figure this out.Any updates?
i completly agree and understand that there is something going on with the valve or seat to not let it seal but from just a visual inspection from the combustion chamber it all looks good. the valve does not apear to be off the seat, but the air came out hard when I was pumping it in like a major non seal.Its the valve or seat and doubt if you can do anything to make it seal. You can take a leather mallet or block of wood and hammer, then hit the valve some to make it bounce (not to overly hard)
Pour some water in the intake side of the valve to see if it runs out around the valve or another place
