Lou C
- Joined
- Nov 10, 2002
- 14,523
I see signs of a blown head gasket between cyls 4&6, see that dark area? if you lift off the head gaskets, are the fire rings all in one piece or are they slit on the side anywhere? That was the cause of water in 2 cyls in my engine and about the same amount of milky oil. The cyl heads had cracks in the center cyls exhaust ports but those cyls did not have water, it was the #2 mostly and just a mist of water in #1.
I guess you can start with taking the cyl heads to a machine shop and get them checked out. When you pull off the head gaskets, clean up the block deck surface really well (no rotary tools!) and look very carefully for cracks.
