merkdawg0084
Thread starter- Joined
- Oct 11, 2017
- 573
Does anyone know what the primary and secondary winding numbers should be when using a multi-meter? Thanks
I thought your motor was running on one cylinder? The pick up and driver coil will not cause that.Thx. How do you like your 9.9? Does it run good? I’ve had mixed reviews. Thx
I've had the 9.9 for about 10 years. Runs good but I don't use it often. I found it's worth having a new set of plugs on hand cause they will fail . Often happens while at WOT and 1 cylinder drops out. I've found it best to just stop and swap for new plugs then carry on. I put points, condensers, 1 coil and a fuel pump in it in 10 years. Always starts on the second or third pull. I still prefer my 18hp over the 9.9,but there are some lakes that are limited so it's nice to have.
what brand of plugs do you use? Ty
ngk b7hs
