Piomarine
- Joined
- May 1, 2020
- 31
I have started a thread for my current project, a 1956 Arkansas Traveler Utility I am turning into a runabout. To push this tin can I have acquired a matching 1956 Evinrude Lark 30 HP, but this motor has seen better days! Until I dig into it I really will not know what I am dealing with. Now I am aware that there are most certainly better candidates for restoration, but this is the motor I have and I will not be allowed to purchase another one...I already got in trouble for buying this one (even more trouble for driving 6 hours round trip to get it!)
So here is what I know:
-The motor is locked and I have no clue why (no oil, overheated, sat too long...who knows)
-The transom clamps are seized (but that is a small issue)
-The gear select does move freely, but I have a sneaking suspicion it may not be connected (I have not checked to see if the prop spins while it is "in gear")
-It does have the starter, but it will also need to be overhauled (I believe it is locked up too)
-All of the wiring needs to be replaced, which tells me this motor has sat unused for a VERY long time
-Finally, I know that I will be in over my head on quite a bit of this...which is where I will rely on all of you.
I have the Gilmer guide, I am aware of the proper fuel
il mix at 24:1 (or 16 oz/3 gal of gas) it is what I use on my '57 Sportwin, and I have already mixed up some ATF and acetone because I KNOW I am going to need it!
My question for the group is simply this...where should I start? (after I get the transom clamps loose)
I look forward to your input!
