Climber513
- Joined
- Jul 2, 2010
- 56
So I pulled my lower off to install a new impeller and while I was at it I pulled the upper off to replace the gasket. Had it in forward gear but during this process I had moved the shifter on the lower unit while greasing it some. So I spun it clockwise and spun the prop ccw and got it back in forward gear. Put it all back together and it was running and shifting fine until I docked it and got the trailer in the water and that's when I noticed I lost my forward gear. It was just rev up but not go into gear. Finally it popped into gear but I ended up losing it again. Got it home and pulled the lower off but nothing looks to be damaged at all. Do I just need to adjust my linkage??
