- Joined
- Jul 7, 2010
- 15,138
I've got a head scratcher going here:
'03 - 3.0 - Alpha one.
I crank the engine, and it won't start. I have spark at the wires, but I'm not skilled enough to tell you how much spark/what kind I have. Fuel should be good, but to test the issue I did shoot some starting fluid in the carb. No joy. Haven't tested compression, but I would think even if I somehow blew a gasket - I would at least get a cylinder or two to fire up. Right?
BACK STORY:
A month or so ago, while towing a family in I caught a line in the prop and the engine shut down. I cleared the line off, and then restarted - everything seemed to be working fine. The next out on the lake, I ran into the problem of the boat not wanting to plane. I could maneuver and move along fine at idle speeds, but try to get it on top of the water and the RPMs would run up, we wouldn't go anywhere. Everything seemed fine otherwise, so I began chasing down a spun hub, thought I confirmed it and put a new hub in the prop.
While I was at it, I decided to change the spark plugs because they hadn't been changed in a while. Had the dude at NAPA cross reference against the AC Delco plugs it was supposed to have, and put a set of NGKs in there. Had 'em gapped at .035 per specs (that I read in one of the Merc manuals). Cranked cranked the engine and it wouldn't start. No stutter, pop or backfire. Just spinning.
After fiddling with it a while, I figured that maybe the plug wires were going bad and I pushed 'em over the edge. So, I just went the full monty: new cap, rotor and plug wires (took forever to get parts). Nope : no change.
Tracked down the correct AC Delco plugs that I think originally came in the engine and found 'em via the local auto parts shop, and also found (in rather large type on the flame arrestor, once I saw it) that the plugs should be gapped at .045. Oops - fixed that. Still nuthin'.
When I test the plug wires, I see spark. But I don't know how to tell how "good" it is (or if I really can).
I'm lost. The boat was running a little rough on occasion before I decided to change the plugs, but never gave me any real trouble. I can't think of anything I've done that would kill the whole starting process.
I could change the coil, it's old enough that changing is probably not a bad idea. But I don't wanna' just start chuckin' parts at it, not knowing what is actually wrong.
Any thoughts before I take it up to the local boat doc (good mechanic, but I don't particularly like the guy)?
BACK STORY:
