Need help finding an upper yoke input shaft for bravo one
ryan04
Hey folks! I just swapped in a new engine coupler in my 2006 5.0mpi with a bravo one drive. When the coupler went it chewed up the input shaft/upper yoke on the drive. I've been looking to replace that shaft but it's proving quite difficult to find one that doesn't cost 500. It's a 17 spline and the retainer clip is on the INSIDE face of the U joint housing NOT on the outisde snapped around the U joint itself.
Which leads me to my question. I've found bravo X input shafts that appear to be the one I need for my 2006 bravo one. Will a bravo X input shaft fit a bravo one drive? It's the same length and has the retatiner clip on the inside face like mine.
Anybody have a line on a good used one?
Thanks!!
There the same length but the U joints are different
Measure the inside and the Reg Bravo will be a tad larger then 1.079, the X will be a tad larger then 1.329 or 1.218 (meaning s/n 0W1000001 and below and 0W1000001 and higher)
Ask at OSO wanted section, someone probably has one
ryan04
Thank you kind sir!!
