froggy1150
- Joined
- Nov 3, 2017
- 881
Also with carpet between pedestal there will be give and crush. When solid things move .... they break. Not good at speed
So what engine enclosure are you talking about here? Are you talking about a doghouse that covers the motor? If so that boat came with a bench seat and a full width sundeck to cover the engine.I've been thinking about how I want to build the fiberglass engine enclosure. I want to make it slick-finished glass like it came out of a factory mold, but I want to shortcut the process by skipping the plug stage. I just want to build a single-use mold with a smooth-surface material. Something like you would use in a a shower.
Maybe a sheet of powder-coated aluminum like I built my camper out of; I could roll curves into that. That stuff's not cheap, but might be worth $75 to build a nice mold with only one seam around the top.. Now that I think about it, aluminum is probably not much more costly than that shower board, and much easier to curve.
I have a good idea of how to brace it on the outside by using adhesive to attach the bracing to the sheeting.
I think the top could be flat, and I could form smooth fillets with caulk.
Anyway, the wheels are turning and the vision is starting to come to me.
When I did mine I laid the carpet first, then I just marked the screw holes, pre drilled, then coated the hole and the lag bolts with sealant and ran them in tight.I could mark the screw holes on the carpet, and then cut away the carpet where the screws will be so I can pre-drill and apply a small bed of sealant for each screw. I'm picturing a round piece of carpet about a half inch smaller diameter than the pedestal base.
The 1750 was also offered with a doghouse and a seat on each side. The seats could be folded inside out (for lack of a better term) to fill in and create the sun deck.So what engine enclosure are you talking about here? Are you talking about a doghouse that covers the motor? If so that boat came with a bench seat and a full width sundeck to cover the engine.
Interesting, I have never seen that browsing the caravelle forums. That was what we liked best was the full bench. Which was kinda rare in a boat that size. Most had the doghouse. You might just try to find a doghouse off an existing boat in a salvage yard or something. I believe the one in your picture is probably wood wrapped in vinyl.The 1750 was also offered with a doghouse and a seat on each side. The seats could be folded inside out (for lack of a better term) to fill in and create the sun deck.
Since It will mainly be my arthritic wife and I in this boat, I plan to go with a doghouse that will flare out to cover the mechanicals at the transom. Maybe one big piece
Nothing on the starboard side. That will allow a place to stand and fish, or just to reach the water.
Port side rear will have steps and a grab pole for boarding. Sure, my boys and I can still leap in like Speed racer into his Mach 5, but my wife and her mother...not so much.
I also want to have one seat at the front of the doghouse. Either molded in, or just ahead and removable. Maybe molded-in back with flip-up base.
They have a new site, in case you are not aware: https://www.caravellefans.com/Interesting, I have never seen that browsing the caravelle forums.
