Gimbal bearing is stuck on my u joint drive shaft
Grub54891
You could pull it with a three jaw puller or cut it off. I think you need to test fit the new one in the housing and see how tight it fits. Also did you remove the retaining in on the outside of the bearing? If its not there its going to be loose.
Bill Bandit
Had the same issue I tackled this morning on a Volvo Penta SX-M. Took a few hours, used my bearing puller, PB blaster, and heat to get it off. My work bench also helped give me some leverage. See attached pics.
Johhnyf13
Thank u for the info i ended u i ended up cutting mine off
jerryjerry05
When you install the drive: the o-rings on the
shaft need grease but grease them after they
get put on the shaft.
Grease under the o-ring can lift the o-ring and
can make it hard to install.
Bill Bandit
Thanks for the tip, I’ll be sure to do this when I reinstall my outdrive this weekend.
