Lou C
- Joined
- Nov 10, 2002
- 14,059
When you blow those pix up you see a lot of pitting, on the sealing surfaces. Remember that sealing surface is what keeps water out of the cyls. Usually you can't see the pitting until you get all the gasket material off and take a good close look. These surfaces should look like smooth shiny cast iron. I would either get them milled on a sanding machine or replace both the manifolds and elbows. If you get Barr Marine aftermarket for the Volvo the kit is about $750 for everything including new bolts & gaskets. Here's a pic of what these look like when new....I found that the casting of the Barr parts was very good, the paint was kind of thin so I'd paint them with a couple of coats of Rustoluim black they will stay rust free longer.
Here's what they should look like to seal right:
see the headless bolts, I used those to keep the manifolds/gaskets lined up when installing.
Look at Volvo's specs for the condition of the sealing surfaces...
Then their gaskets require the use of the copper based spray sealer...
I used the gaskets that came the Barr kit they are a thick composition gasket, and coated both sides with Permatex Aviation sealer and no leaks.
When installing the elbows, to keep it all lined up you can use the same trick with 2 headless bolts, take the standard bolts, go to a hardware store, get 2 longer bolts for the manifolds, and elbows. Then cut the the heads off and cut a slot in the end of the headless bolt for a screwdriver slot to make it easy to remove. This helps keeping the parts lined up esp with the elbow gaskets coated with sealer they like to slide around.
