Lou C
- Joined
- Nov 10, 2002
- 14,524
You seemed to be focused on water entering the cylinders via the exhaust . . . Maybe it is not.
You don't seem to be getting a lot of water, otherwise you would have experienced a hydrolock and the resulting damage to the engine.
Perhaps the water source is within the engine. . .
Head gasket
Valve guides
Intake manifold
Maybe a compression test, a cylinder leak test, and a cooling system pressure test are in order. (I did not see any such info above unless I missed it)
Double check the 15" height on the height of the elbows above the water line. It seems high enough to avoid water ingestion, but not sure of the spec. (FWIW - my boat - with added swim platform - has the elbows at about 12" above the water line, the spec is 13", so I'm a bit shy of the spec.)
The challenge with added swim platforms is that you can have more people at the stern of the boat and at a point further aft. So this can make the stern sit lower than the boat builder anticipated in configuring the exhaust. It does not seem like you have that issue though.
I would run the tests and if all good, see about adding a riser between exhaust manifold and elbow.
this is always a possibility, in my experience with blown head gaskets, it is more consistent than some of the these reports of water intrusion. With the just high enough elbows, or and added swim platform, the conditions have to be just right for it to happen, so it may happen sometimes and not others.
On the other hand when I had my leaking head gaskets, I found that it would consistently happen. I could run it on the water hose, shut it down and check for water in the cyls (#2 had water, #1 has just a spray of water). Right after shut down, nothing. Wait a few hrs and sure enough there it was, every time. So when the engine was hot, the gasket seemed to seal but as soon as it cooled off it allowed seepage into the cyls.
What I'd do...
if the boat is raw water cooled....get some reinforced clear hose of 3/4" inside diameter. Replace your manifold feed hoses from the thermo housing to the manifolds with this. With the boat in the water run it long and hard enough to get the engine warmed up, so the stat is open (temp gauge at about 160-165*), then with someone else driving look to see if you get bubbles in these hoses....if so that's a sure sign of blown head gaskets, or a cracked head. Combustion gas getting into the cooling water. I can up with another way to check for this with the boat on land on the water hose but same idea. Also, look under the valve covers for mayo like coating of emulsified oil. If you get this consistently with bubbles in the cooling water, time to pull off the heads after doing a compression test. If not, and this is just an occasional problem, it could be exhaust related.
