demarko210
Thread starter- Joined
- Jan 2, 2015
- 655
Captains,
Ok while changing out the port side thermostats i was trying to get my cover back on. What is happening is when i place the cover over the thermostat on the port side the left side screw seems to not want to thread into the hole. When i remove the cover and thread the bolt into the hole its threads fine. Anyone every come across this issue? I will try to grind the housing with a Dremel tool a bit.
