03 150 Saltwater EFI thermostat housing
demarko210
Captains,
Ok while changing out the port side thermostats i was trying to get my cover back on. What is happening is when i place the cover over the thermostat on the port side the left side screw seems to not want to thread into the hole. When i remove the cover and thread the bolt into the hole its threads fine. Anyone every come across this issue? I will try to grind the housing with a Dremel tool a bit.
Dukedog
ya might wanna rethink tha grindin' part.. something is wrong when tha right bolt won't work in tha right hole on tha right part.....
did you try any of tha other three bolts in that cover in that hole?
demarko210
Yes i tried the other 3 bolts to try and fit into that location. Same thing they did not catch the thread. It catches when i just thread the bolt though.
I didnt mean i will grind but just clean up the surface area and see if it helps. Also I will clean the threads on the bolts with wire brush.
Dukedog
tha other bolt (same housing) tighten down right right?.. tried without t-stat and rubber?
demarko210
correct. I just cleaned the bolts with degreaser and wire brush. One bolt had metal thread halfway around the one thread about 1/3 the way up. I did not try with out the rubber.
demarko210
ya gonna need to heli-coil that hole more than likely then...
I am going back over to the boat and clean the housing and surface area and see if i can get better results. I will update in a few hours. Thanks i will look at the heli-coil kits and see if its something i can do.
demarko210
gl with it......
So i found the issue. See the image attached. It seems as if the housing is taller on the portside. Can you see the difference? Now i dont know if i should buy a housing and see if they are the same or try to find a bolt.
demarko210
Fixed it with a bolt from Home Depot. Mercury called for M8 X 25 used a M8 X 30 and it fasten right up. I may take the bolt and paint it to keep the corrosion down. The gunk around the top is the Permatex No. 3 i was using. Moving on to the electronic switches and I will be sailing!
Thanks again.
