Doorknocker1
Thread starter- Joined
- Oct 18, 2020
- 11
1955 Johnson 5.5hp How does the water pickup tube connect to the water pump to the powerhead.. just replaced the impeller and have no water pumping out of block
Thanks!see pict btw you did install the impeller key ....
I missed the pickup tube into the impeller grommet.. it’s all good.. rookie mistake.. thanks!Thanks!
Thanks!Quite briefly, water enters through the screen on the forward edge of the underwater exhaust snout. From there, it travels along behind the rectangular plate on the side of the gearcase, to the area below the stainless steel plate below the impeller, through the hole in the plate, acted upon by the impeller, out through the pump housing outlet, through the copper water tube, up to the passages under the powerhead gasket, then through the powerhead. All this will be obvious if you are trying to track down a blockage, which you probably don't have anyway.
