water pump
melapatt1973
I replaced my water pump on a 1998 60hp elpto 2 stroke and I have some water coming from pee hole but there is also water coming out on the back side by the 2 braces there is a little hole
melapatt1973
I would say its about mid ways on back side of unit water coming from another small hole that is right in front 2 braces on unit
melapatt1973
I have a 1998 60 hp 2 cycle 3cylinder outboard and I put in a new water pump and I have water coming from the pee hole but not like super strong and about straight across to the back side of unit there is a small hole in the unit and it looks like where the arms connected to the unit to raise and lower it. But I have water that boils out of that hole as well its not strong but a good amount of water while idling
melapatt1973
I have replaced my water pump and I have low pressure and I have water coming from a small hole where the motor brace attached to the mid part of the motor. I have taken it apart 3 times and I am pretty sure I got the tube stabbed right. And does the impeller have spacers on each side of it?20210419_155011.jpg20210419_155018.jpg
melapatt1973
I called the marina and they said to make sure the tube is on the tube coming down from motor but I have did this 3 times now and I keep getting the same results. I also didn't have any little seals for each side of water pump and my kit didn't have any
