forums.iboats.com
All good now fixed thanks2001 Johnson 40 not turn over
2001 Johnson 40 electric star, when you turn the key the oil light stays on and will not turn over?forums.iboats.com
OK, one more time around. The motor must be in neutral to start. While turning the key to start (turn and hold there), rock the gearshift back and forth and see if the motor cranks. If successful, remember that spot when starting next time (neutral detent).
Ayuh,..... So what was the problem,..??..??All good now fixed thanks
