I've been working on this thing for awhile. Came with pressure tank. Had to get a gasket and parts kit. Went through the tanks gaskets as well. The tanks pump knob leaks fuel a little bit when I prime the carb. My question is... The engine will start when using starting fluid and it will pull fuel as I look through the carb. It then stops pulling fuel and dies out. This varies in length of run time. Any suggestions for which way is most likely the problem? Note I just took the carb back off. Cut a new bowl gasket and blew out the holes and slow jet.
