Hi.
1987 v4 110hp
Not totally sure of the model number as the sticker isnt there my best guess is J110TLCUR.
I'm at my ends with this motor.
I'd take it to a shop but they are 3 weeks booked up.
Cyl 4 not running.
Tested spark with a spark gap tester
Changed coils
Changed plugs
Changed leads
Changed cdi units
Checked and swapped reeds
Head gasket replaced
Checked timing
Tested the pickup and stator
Spark gap tested
Carbs cleaned and swapped
Cleaned and added extra earths
Sprayed some engine start around all the hoses and gaskets listening for any pitch change in the engine bit nothing happened.
Head gasket was replaced as I thought maybe water is leaking in, cleaned the head and block surface and checked it with a flat edge ruler and all came up to spec.
Compression tested all cyl around 100
Put compressed air into the crank and listed for leaks through the carbs (nothing)
Vro replaced with normal pump
Motor starts and will idle on muffs but won't in the water.
Cyl 4 has spark, fuel and air but doesn't appear to be doing anything (I can take cyl 4 lead off and on while the engine is running and it makes no difference to the engine pitch. As soon as I take off the lead i can see the spark coming from it to the plug.)
What else can I check ?
1987 v4 110hp
Cyl 4 not running.
Changed coils
Changed plugs
Changed leads
Changed cdi units
Checked timing
Spark gap tested
