From what I have found I think this: https://www.amazon.com/Sierra-18-6768-Compete-Assembly-Mercruiser/dp/B002IV6RXS may be a modern replacement. It appears to have female fittings coming out of the base of the pump but I'm right by a Tompkins and can always either pull those fittings out and put in a male fitting or use a male (whatever fitting and size it is on the pump outlet) to -3 male coupling in order to connect the lines. The part I am worried about is electrical connections. I do not know if it is a plug and play with the original wiring harness or if I need to redo stuff.
Also I am in Iowa.
Also I am in Iowa.
