76SeaRay
Thread starter- Joined
- Aug 24, 2017
- 1,071
I saw a note in another thread that mentioned something about the Alpha 1 Gen 1 water pump does not provide enough flow for use with a closed cooling system. I have a brand new closed cooling system setup and brand new dry joint manifolds for my 5.7L Vortec. Is it true that the Alpha 1 pump will not be enough? If that is true then do I need to run a Seawater Pump as the answer to the problem?
Thanks....
Thanks....
