bman1bpm
Thread starter- Joined
- Jul 19, 2004
- 450
I replaced my plugs/wires/cap/rotor.
The boat was running fantastic. Started better than ever. Then after 30 minutes on the water it sputtered and died. Now it won't start. It is a 2001 5.0 alpha 1 thunderbolt v ignition carbureted motor.
It won't start on starting fluid either. I got my spark tester out. I have a weak spark on the coil wire, none on the plug wires. When I pulled out the old wire from the coil it was very difficult to remove. It looks like a rubber piece pulled out in the wire connector. It doesn't feel like the wire is really getting a good connection. I posted a picture of the port on the coil. Does it seem damaged?
