No spark possibly coil?
bman1bpm
I replaced my plugs/wires/cap/rotor.
The boat was running fantastic. Started better than ever. Then after 30 minutes on the water it sputtered and died. Now it won't start. It is a 2001 5.0 alpha 1 thunderbolt v ignition carbureted motor.
It won't start on starting fluid either. I got my spark tester out. I have a weak spark on the coil wire, none on the plug wires. When I pulled out the old wire from the coil it was very difficult to remove. It looks like a rubber piece pulled out in the wire connector. It doesn't feel like the wire is really getting a good connection. I posted a picture of the port on the coil. Does it seem damaged?
nola mike
That whole mess looks pretty corroded. I'd start by cleaning all your connections. Guessing a lot of other connections look like that as well.
bman1bpm
One saw it in a picture it does look pretty crusty. Can't tell when it's way in the back of the motor in the bilge. I'll just order a new one and clean my connections. Will update
doubt its the coil. usually never is the coil being a 2001 most likely it is the trigger assembly in the distributor (common issue). do you have the old 2-wire trigger assembly (failure prone) or the newer 3-wire. the old two wire ones were also not conformal coated.
if you have the 2-wire, it most likely failed.
achris
More fish than mountain goat
Jump onto my Thunderbolt ignition, how it works, posts. All is explained in that, and includes a troubleshooting flowchart so you don't have to spend money 'shotgunning' the parts.
bman1bpm
Thanks! I read it the other day but the images weren't showing up. Now I can see them.
bman1bpm
I had the old 2 wire. Went ahead and replaced it with the new 3 wire. Still didn't work. Popped in a new coil and it fired up. Sounds like the sensor was a ticking time bomb anyway though.
