- Joined
- Mar 5, 2006
- 30,711
Which is why you follow the manufacturer's load charts and don't just fill them up to Max PSI!Internet forums are great for pointing you in a direction, but trust the verified sources (manufacturers, etc.) for the final say.
I upgraded tires to a larger size on my last trailer. If I loaded them up to Max PSI, they would be extremely overinflated. You go by the PSI recommended on the tire label on the trailer if you have the sized OEM tire. If you don't, you use the load charts.
