CamaroMan
- Joined
- Mar 18, 2016
- 330
Hi - looking for the timken bearing number for the 1-3/4 OD drive gear used in the upper, (im presuming both use the 386a race). fwiw the 1-7/8 bearing number is 386A - i ordered a 24/24 gear set for an alpha 2 part # Sierra 18-6350 (cant read drive sn)- but the ID of the new gear is 1-3/4 and the bearings are 1-7/8, so trying to see if I can swap the 2 bearings to match the new gear set?
This item
matches my new drive gear number and the bearing number is 25580 - not sure if that bearing is compatible with the 386a race? or if i need the matching race as well - it uses the housing style- im trying to cross a bridge here :/
Thanks
This item
Mercury Mercruiser Quicksilver ALPHA 43-853640 2641 24/15 Tooth Gear Bearing | eBay
BUY IT NOW! Best Wishes! I will be diligent to help you make your purchasing decision.
www.ebay.com
Thanks
