Cassidy0013
Thread starter- Joined
- Sep 9, 2021
- 15
Hi I am have some issue on figuring out why I have no power to my tilt and trim relays. I have a 1996 Johnson 150.
The only fuse is the 40amp. Everything looks good as far as connections go I’ve even pulled back the housing on the wiring to where all three Buttons come together being the one at the throttle the one on the motor and the one by trolling motor and no power I have a red green and blue wire and I’ve checked all three while pushing buttons at all three places and nothing and the battery is good. I also failed to mention the boat has set for 6 years. I’m sure I’m missing something some where just not sure.check for any fuses ...? all connections secured, shiny.
My understanding is the tilt and trim has constant power meaning I don’t have to have the key switch turn on right? And am I wrong in saying the power comes from the starter solenoid if so can a bad solenoid be the problem I’m also have the stater off. In the process of changing it out. Being the reason it set for so long and just decided to try and get the old girl going again as a project.The only fuse is the 40amp. Everything looks good as far as connections go I’ve even pulled back the housing on the wiring to where all three Buttons come together being the one at the throttle the one on the motor and the one by trolling motor and no power I have a red green and blue wire and I’ve checked all three while pushing buttons at all three places and nothing and the battery is good. I also failed to mention the boat has set for 6 years. I’m sure I’m missing something some where just not sure.
Where is said 40 amp fuse?The only fuse is the 40amp.
It’s a 90 v6What model motor? 60*V6 or 90*V6?
So no power at the trim button on the cowling? On my '98 Johnny 60*V6, the power for the instruments, trim, starting etc., come from the same 20A fuse on the wire at the starter solenoid. If that fuse blows, no instruments work, the trim doesn't work and the motor will not crank.
You need to trace power back to the fuse from the trim buttons on the engine. Remember if the motor has relays, they need a good ground on both the relay primary and secondary windings.
Trim fuse is a 20 amp in-line located next to the relay box
You have power at the fuse?And yes it’s a 20 fuse sorry.
So I have power at the relays now. And I check the tilt and trim motor and they work. But like I said earlier in the post that I am in the middle of changing out my starter and I don’t have the - wires that ground to the block attached would that keep the tilt and trim switch from working?You have power at the fuse?
Let’s go upstream…you have power at the terminal by the starter?
Do you have a power strip at the relays or not?
Yes.So I have power at the relays now. And I check the tilt and trim motor and they work. But like I said earlier in the post that I am in the middle of changing out my starter and I don’t have the - wires that ground to the block attached would that keep the tilt and trim switch from working?
?? it is fixed yes no ? So I have power at the relays now. And I check the tilt and trim motor and they workOk so if the relays are not clicking then there bad right is it common for both to go out? And like I said it’s been sitting for six years
