Keith7481
- Joined
- Aug 21, 2005
- 126
Hi all,
I've recently purchased a 2016 Four Winns H260. My previous boat, I winterized myself by draining the block and pour antifreeze into the hoses. New boat has a 350 volvo with a closed cooling system and heat exchanger. The (red) engine does not have the valve that can be opened to drain the block but has a tube with a garden hose fitting for flushing the engine after salt water use. The coolant in the radiator is good at -45. It was suggested to me that I can pour 2-3gallons of antifreeze into the flush tube until it runs out of the prop and that will winterize the heat exchanger.. As I have a pretty significant investment in this boat, I'd like to be sure that this process will actually take care of the heat exchanger? Any advice would be appreciated.
Keith
Keith
