Needed to rebuild carb so had to remove starter bracket and disconnect some wires to get to the carb nut. My dumb self did not take a picture. Got called away for a week and now can't figure out wiring.
The wire in the black box is a ground running back to the battery. There are two wires in the yellow box. One is the positive wire from the battery to the solenoid. The other runs from the push button start to the solenoid. So far so good. All seems to make sense.
What is the wire in the red box? It's length and bend suggest it goes on the same bolt as the ground from the battery, but ugly things happen when I do that. The wire seems to be terminated on the case near where the tiller enters the case, but hard to see so not positive about that.
Any idea where that wire goes or do I have this all screwed up?
