Hi, I have a 2001 wellcraft 270 coastal with a mercruiser 7.4 MPI with a bravo 3 outdrive 22 pitch prop. Late this summer the lower shaft upright shaft snapped and I couldn't tell what ratio I had so, I took a shot buying a bravo 3 gear ratio 2.20:1 and the guy had the same engine but, his outdrive upper drive gear bearings was broken so, I used my drive gear that I had from the outdrive that was on before. Now Running the boat at 4000 rpm I am getting 18 mph but before with the old drive at the same rpm I would get 25-26 mph. Today I pulled that boat out of the water and opened the top cover of the drive and I counted the teeth and it has 23x30 and the 23 teeth it was the old drives upper drive bearing and gear. So i'm guessing the old drive that I had before was also 23x30 with means that gear ratio is 2.20:1. Does anyone have the same boat and motor and what gear ratio do you have? Do you think I have a outdrive issue or engine? Don't know what to do anything helps.
Thank you
Thank you
