Will do thanksYou could raise it 1/4" at a time and test run.----Some will argue , but that would be my approach.
Ayuh,...... So take the blue wheel offa there,.....Hi guys not sure if this is the right place for this topic but I got a sears 12ft aluminum boat. Transom measures at 15” my problem I’m having is attached in the video below. I have water spraying up from the back of the boat when going fast. You can see it splashing against the blue wheel. The motor is a short shaft evinrude 9.5 however I noticed that the cavitation plate sits below the bottom of the boat. Could this be the reason? Should I raise the motor more somehow? Thanks
I definitely learned this lesson all of my 7.5hp and below outboard never had this issue this 9.5 seems to be the only one where I’ve had this happen.Sit a boater up front, trim motor to 90 deg, install a 1/2 inch wooden or hard cork shim under the motor, go for a wot run on flat calm water condition, check by looking backwards if the splash side or over the transom was cancelled, if still persists replace current shim for a 3/4 inch one.
Right now the water flow at speed is banging the non edged portion of the lower leg when needs to pass thru the edged portion under the samall upper plate to avoid any unwanted water splashes. Each boat motor combo has its unique and precise installation which needs to be height fine tuned if in pursuit of top boating, it's not that easy peasy as to sit any motor on transom snap your fingers and voila!!
Happy Boating
Absolutely not. Waste of time. That motor is waaaaayyyyyy to deep in the water.this was taken after raising the motor 1 inch. Should this be good to do a test run?
Never saw an engine do that. Course I never saw a RIB. Whether its purely a RIB phenomenon or something else, who knows....surely Sea Rider does.A dry boat motor install says nothing to me, what the OP needs to do is go for a wot spin with deck load well distributed, new shimed motor height and once on plane on flat calm water cond pull head side of motor and Visually check what's going at back transom.
Need to determine where is the actual hardened exiting water flow is pasing by at spped to know if the 1/2 inch shim went well or need an extra shim height. To the OP, was the combo having water splash issues back or over transom as in pic ?
Happy Boating
Go to the lumber yard and get a piece of wood....HD or Lowes for a couple of sources.Thanks for the input sea rider I set the trim as you state to 90 deg level with the bottom of the boat. Exactly what shims are you referring too and where could I purchase them. I’m thinking based off your previous picture that the water level is above the small upper plate on the 9.5 and that is what is causing the splashing. The water was also slightly going over the transom I would like to add.
"The rear boat's bottom must be impeccable clean before water testing or will produce an uneven water flow passing thru the lower leg, report your findings, good luck !!"OK here's the deal : To understand, right now the water flow at speed is banging at the non edged lower leg portion (red line) when should be passing ideally under the yellow line right under the upper plate. That motor has a very tall gap between plates.
Surely one will say that with that setting there will be more lower leg water drag, in reality it's impossible to quantify how much as there's a tall sharp edged portion (green line) right at middle of both plates that will cut the flow nicely at whichever height the flow passes. Will discuss that issue when the water splash has been canceled.
To raise the motor go to a store and buy a thick cork panel, the ones to pin things on them, cut a portion matching the motor's swivel bracket width along the transom's edge width. Sit the motor keeping it at 90º and test, if still splashes add one more cork shim over it and test again till the splash is finally canceled. Can use a wooden shim made to size as an alternative. Whichever is faster to buy or make.
Happy Boating
I don't see the engine sitting too low. Looks like its sitting just right putting the top of the water flow in the center of the green line on plane at WOT and 90* tilt as you mentioned.
