I’m looking to just use the one.most have a start battery and then a house battery to run electronics so you should be able to always start the motor
Just need to set them up properly
Already burnt up a nice agm. 2 years old and fried a cell, over charging, so flooded is my answer there. As to why, cause I run these in my ag tractors and have a great line on them.
Not sure how that relates to model that is 12 years older. (2001)Yamaha seems to think that the F115 is compatible with AGM lead acid batteries. Been approved by Yamaha since 2013.
I know my 2001 F115 TLRD put out 15-+ volts at WOT. That’s what I’m attributing my AGM failure. Extra weight in my barge doesn’t bother me at all. Just want to safely use this battery with that engine.Not sure how that relates to model that is 12 years older. (2001)
Even if true, I take issue with purposely over charging an expensive battery in direct violation of a battery's warranty Terms and Conditions.
The advertised output of the F115 is 15.0 V
Maintenance Matters - Yamaha Outboards
Stay informed on essential maintenance practices for your Yamaha outboard. Find expert advice and helpful tips to keep your engine in top condition.maintenance.yamahaoutboards.com
AGM batteries are designed for use with AGM battery chargers with a MAXIMUM output voltage of 2.4 volts per cell(14.4v for 12v batteries and 19.2v for 16v batteries). AT NO TIME during charging should the battery be subjected to more than 2.4 volts per cell. Improper charging can cause damage that is permanent and WILL VOID THE WARRANTY.
The same doesn't hold true for the larger outboards (F150 and up) that have 14.5V outputs.
That said. Guages my be off some, but overcharged is still answer I got from dealerI know my 2001 F115 TLRD put out 15-+ volts at WOT. That’s what I’m attributing my AGM failure. Extra weight in my barge doesn’t bother me at all. Just want to safely use this battery with that engine.
Thanks for the feedback. Love this site
I don’t care what they say…tell that to the AGM manufacturer that denies your warranty claim when they point out the use of a 15V charging system.It relates because Yamaha says that the electrical generation system of the F115 is compatible with an AGM lead acid battery. The age is irrelevant.
