Abchdjjsns
Thread starter- Joined
- Feb 3, 2022
- 20
So the story is that i got a seized sterndrive so split it in half and found out the upper was seized and the lower on the other hand would turn, So i drained the lower and Lo and behold water came out, so it seemed like someone was so intelligent that they put water instead of oil well at least the lower turned but it doesn't spin freely tho, so would that be ok or should i change the bearings in the lower, now we go up to the upper first thing i did remove the top cap and what i saw well it was expected saw rust every where so tried soaking it in oil for a month only was able to get that bearing that touches the top cap to turn so instead of waiting i disassembled the whole thing and found out that every bearing is seized so what do you think should i do ??
