Small engine replacement. LoveJoy shaft connector. How does it remove?
massimofinance
I am going to replace the engine on my wood splitter with a predator from HF. I found one video online on how to replace the love-joy but had two questions for this group.
1). When I unbolt the engine, will it just slide off the shaft that is connected to the pump?
2). It seems the love joys attach to each shaft via a small “keyhole” hex bolt. Any advice on how to disconnect the one on the engine shaft side? Worried it will strip out.
Yes, just pull the engine back pulling the jaws apart.
You can simply loosen the set screws and slide the jaws apart on the shafts
There are 2 jaws and one coupler spider
Grub54891
It just pulls apart. Then remove the setscrews and install the new one. When changing the motor, sometimes the motor shaft is a different diameter. You may have to contact the company and tell them the measurements to get the correct sizes on both ends.1645534835164.png
massimofinance
Thank you both. Do you know if the Briggs and Stratton 5hp has the same shaft diameter as the Harbor Freight 6.5hp Predator?
massimofinance
I need to measure it but think it’s 5/8”. I suppose I can still get the predator (the price is great) but get a new love joy? Any better way to match up the pump shaft and the crank shaft?
Grub54891
Get the motor, check the shaft and if you have to just get a new Lovejoy and mate it to the old Lovejoy. Use half of each one.
matt167
A 5hp Briggs should have a 3/4" shaft. That swap is about as easy as it could get. The base plate dimensions are the same. But the clone engine will require new bolts due to the thicker casting.
dial indicator.
the lovejoy has a max axial limit of about .015
massimofinance
Thanks all. The set screw on the Lovejoy mounted to the engine will not come off at all I’ve twisted up two Allen wrench. Sprayed it with penetrating oil and used heat. Nothing. Any advice? Amazon sells them but I’m not sure what size I need. Thanks.
matt167
Predator is 3/4" shaft. I think the second is the diamater of the coupler itself.
Tractor supply or other farm store carries them as well.
Use a torch to add heat and an impact driver
Most allen wrenches are made out of peanut butter. A good quality allen wrench will break before it bends.
Grub54891
If you already twisted two wrenches, were they the wrong size? Inquiring minds would like to know.
also you could drill the set screws if you have good drill bits. It’s not a perfect solution but it may work. If you are scrapping the motor, worst case, cut the motor shaft, then get a puller on there. It may get ugly.
