130 Johnson leaking fuel and flooding Cylinder
Cdamnro22
What are these holes and why would fuel leak out of them after motor has been running it also floods it and won’t start back
Crosbyman
holes are for balancing carb internal air volumes... do all carbs leak ???
could be a simple float/inlet needle issue on 1 carb but 4 ???? IF so fuel pressure may be exceeding the float capacity to block fuel ingress. Think of them as small toilet bowls.
simple designs & auto cut-off when full.
Is this a new problem or old problem.... anyone worked on the carbs lately ??
Cdamnro22
New
could be a simple float/inlet needle issue .
just started last time we was on it what would be easiest fix and no just the bottom left
Take carburetor off inspect float and float valve.----Check carburetor bowl for warpage.
Cdamnro22
Update got it to quit leaking fuel but won’t stay running at Idle Engine has to be has to be wide open to stay running and if you start it and the motor is up as soon as you let it down in water it dies but it fires right back up
