OUTDRIVE
dubs283
No need to yell
Remove rear cover, remove shift linkage pin, trunking and jam nut. Remove hinge pin(s). Remove six mounting nuts. Remove drive. Have a stand or helper ready to aid, drive is heavy and awkward
No need to yell
Thank you very much, The big question is I need to replace trim cylinders because I could not get the gland nut off for the life of me. So once I remove the drive is that easily accomplished.
Do you suggest an entire replacement of both pistons or just as needed?
And...
is there a schematic you can share so I know where to find the above mentioned items. This is my first removal.
Thank you so much again!
Garrett
SavinRaven
Garett get the shop manual to help you also watch a few youtube videos.
