Lou C
- Joined
- Nov 10, 2002
- 13,698
Have to agree on that newer style Merc single point drain, I've never seen so many plastic fittings, hoses all over the place, just to avoid doing what it SHOULD have in the first place, a closed cooling system! With that you can use a pressurized tank hooked up to the muffs and run -100 AF through it and be done. I would never install a new or reman engine without closed cooling.
I bet if you added up the cost of all those plastic bits, hoses etc, the closed cooling is not that much of a cost penalty, and is so much BETTER, because it is pressurized and cools better and prevents corrosion if maintained.
