Fuel pump push rod?
dpar
I have a 5L 1995 0MC, (19' Four Winds),OEM fuel pump died. My manual states to slip a small screw driver under the push rod to support it. However after barely pulling out the old pump I could not feel the push rod, upon removal no push rod is visible. I'm wondering if my pump (3854053) even uses a push rod since it has a long lever. I've attached a picture of it.
Thats a ford motor, the pushrod is on a GM motor.
Are you looking at the factory manual or a seloc/haynes/clymer
dpar
I bought a 2006 PDF Manual master, now I'm doubting its accuracy. Thanks for confirming no rod.
