Hi there
I'm hoping someone could help me out with an issue i'm having with my motor ,
i have replaced the following parts , spark plugs , new leads , CDI box , coil packs x 4 , starter motor , propeller from 17 pitch to 19 pitch , fuel filters x 2 , water seperator filter , fuel line with primer bulb , tune up , compression is at 130 on all cylinders
the problem i had was it appeared to be taking in too much air & bogging down when going into full throttle , after replacing all of the above it appears to be much better but i can't get passed 27.5 knots on flat water , i'm really at a loss as to why this is happening & hoping someone could give me an idea or recommend what the fault could be
regards
Ron
regards
Ron
