Tally Marx
Thread starter- Joined
- Jun 9, 2022
- 15
Second post here folks,
50HP Evinrude, 2 stroke. Electric start and has what I believe to be an electric choke system turned on by a solenoid. I have 2.5 ohms when leads put on solenoid lead and ground (both block or bolt as in photo).
When switched to VDC I have zero when the key is turned into the ON position and pushed in. I also do not hear a click or see the plunger suck in and close the choke. This leads me to believe I am not getting voltage to the solenoid for it to close but my solenoid may actually still be good.
There is also a lever at the throttle for choke which I believe to be disabled so that the electric choke runs the show. (See photo)
Either way, only way I can close choke and run engine is by manually closing the flaps and then engine starts.
