yarinzimmerman
- Joined
- Jun 1, 2022
- 16
Hi,
Here's my T&T components off a force 120 (1992 most likely). It will raise the outboard barely but won't bring it down at all unless I apply immense pressure on it while I trim it down (T&T motor will spin though).
A few questions if you will:
Regards,
Yarin.
- The part where the hydraulic pump sits on have seen better days, can you please advise where I might find one?
- Same question about a kit of seals and o-rings. I'm having trouble uniquely identifying these components. I've looked here and here but it doesn't seem to match my unit
- I'm most likely going to try and find a local shop to rebuild the electric motor (although it's working). Should I not bother and look online for a new one instead? Since I can't identify the exact part number I'm not sure about prices
- Last question - I assume the pump itself it OK but the combination of the electric motor and the sealing issues causes the trim not to take the outboard down. Can you guys please advise if my initial diagnosis is in the right direction?
Regards,
Yarin.
