I bought a Faria Temperature Gauge and wanted to install it on my '91 90-HP Johnson 2-stroke. The instructions say to remove a head bolt and make sure the surface if tight/flat against the cylinder head.
It appears there's some other cover (water jacket?) on the outside of the cylinder head. There aren't any really good flat areas on that cover. There are some ribs and low spots. There appears to be a ridge under every gray painted bolt that is higher than the cover surrounding it, so the sender won't likely mount flat against a metal surface and actually have a 1/16" or so gap under the sender.
I could drill another hole in the mounting bracket of the sender closer to the actual sender part and mount it on the top of the starboard cylinder, pointing at 3:00-4:00 direction. But the bracket is not much wider than the raised area on the cover under the bolt. I suppose I could use an extra washer maybe?
I suppose I could also put some of the white CPU/Heat paste inbetween the sender and head.
Has anyone been able to find a good place to mount this surface-type temperature sender?
Here are some pictures of the mounting area
Port:
Starboard:
Side View:
Sender:
Port:
Starboard:
Side View:
Sender:
