Grub54891
- Joined
- Jun 17, 2012
- 6,214
I retired a couple weeks ago, cleaning out the toolbox, I found a bent one. Yes it’s bent from removing the drive in gear. The bend is towards the top/neck area.
Ayuh,..... Congratulations,.....I retired a couple weeks ago, cleaning out the toolbox, I found a bent one. Yes it’s bent from removing the drive in gear. The bend is towards the top/neck area.
Congrats on the retirement! Obviously, difficult to see any bend but not questioning it! So I’m assuming you put the drive back in and had the same issues I am having. Shifts like butter when engine not running??? Took it out on the water today and did more cable adjusting but to no avail! Gonna go and pull the boat out tomorrow and remove the bottom end! I haven’t come across any you tube videos yet, but is it difficult to remove/replace this intermediate shaft???? Thanks!I retired a couple weeks ago, cleaning out the toolbox, I found a bent one. Yes it’s bent from removing the drive in gear. The bend is towards the top/neck area.
This has been a headache for several weeks now! Will be pulling the boat out today! I’ll keep you guys posted! A water pump replacement will probably be a good idea also! Thanks !!Yeah, that’s from when I worked at a shop rebuilding drives. Had issues after the rebuild, after exhausting troubleshooting it boiled down to that. The owner had removed the drive himself so it was something I didn’t check/ find right away. Ugh. I actually had it my hand today to throw away, then remembered about your issue. Yeah it’s hard to see where it’s bent but it is.
Once you split the drive it’s easy to replace it. And much easier to re-assemble if you pull the entire drive and have it on a fixture upright for re-assembly.
OOhh... That's a nasty one! Never saw a bent shoe up there!
Looking at it, seems that the shoe would/should be the weak link of that articulation! A thin u shaped piece of metal vs a big solid shaft! Can’t wait to look at mine!!!OOhh... That's a nasty one! Never saw a bent shoe up there!
The shifter moves smoothly from neutral to forward to neutral to reverse or any way you want, like it always had! Start the engine and now we have the problem! Not that easy to get in any gear or out of! Eventually, yes, but it will get stuck in f/n/r! Even though the intermediate shift shaft doesn’t appear to be bent, it could possibly be, so it’s on order! New bellows, gimble bearing and lower shift cable were installed! Maybe the lower shift cable was not properly installed?Just curious for a bit more information here... you are in the water and with motor running - it has trouble coming out of gear? Or does it have trouble going into AND out of gear?
It happened to mine as well, well it was bent before from the previously owner. Got stuck in the harbour because it wouldnt turn fully and had to be towed.You’ve probably seen a lot of ‘em! I’m starting to think something else could be the problem! Two in 20 yrs. ??? Odds are now, it is something else! I’ll keep you posted!
Nope,.... The safety wired set screw is supposed to be screwed in, so that the piece can easily rotate, without fore/ aft movement,.....One last question; the black plastic end of the shift cable(the crooked 1:00 position part) has about 1/4 to 5/16” of fore and aft movement on the white plastic sheath/cable. Is this normal?????
