johnson 70hp 2 stroke 1995 shut down when warm
gabd
And by the way, because I'm not aware of your boating knowledge, you did make sure you have oil in the reservoir? Because if your alarm is malfunctioning and no oil......
(No disrespect intended) Also, you can just check for spark you have to check for GOOD spark. That means a tester that measures how far the spark jumps. Again, if you didn't do anything reckless, and those tests check out....old dirty or water contaminated fuel or the vro needs help.
i always make sure i have enough oil
i test drive it with the quarter tank of the last owner when i bought ...and since then i just put brand new 91 octane gas in it
saltchuckmatt
From what I understand octane is not an issue but stay away from ethanol.
airshot
When it starts to die, have you tried squeezing the fuel line ball? Have you checked fuel filters? Is the fuel hose bad?? I would start with the easier stuff first if it were me.
gabd
actually i notice the squeezer on the line was not as full as when i prime it ..... and i have the feeling i was running longer time when my buddie was pumping it on the wAy back .......the line is in good shape i havnt check the filter yet.....
airshot
Also clean the pickup in the tank. The outside of your fuel line can look perfect, it is the inside that fails and cones apart. Also the valve in your squeeze ball can become clogged with small bits of fuel line when they come apart as can the plug going into your motor. Your issue sounds fuel related so go thru the fuel delivery system thoroughly!!! If it is old then I would just replace it all to prevent future issues. If I remember correctly the life expectancy of the fuel line is something like 5-6 years...
gabd
thank you very much for the help ....im bringning the boat to my friends garage today i will chek all that
hopefully that will fix my issue
gabd
is the primer bulb on the fuel line is supposed to stay full as when i prime it or its normal to get some air in it while using the boat
gabd
yeah i was thinking about trying a portable tank
i will defenitly do compression test tonight i will give you the result
and here i attached picture of the gas tank setup and model number of the engine
saltchuckmatt
Your outboard is a 1992 by the way.
saltchuckmatt
sorry about that
No worries, just thought you might want to know. Model number J=Johnson, 70=hp, T=trim and tilt, L=Long shaft, EN=year.
Here is the conversion.
Does the hose / fitting for the tell tale come off the side of the block ?----Or was it moved to the top as per a service bulletin that came out in 1994 ?
gabd
hi everyone
yesterday i did compression test and that end up being very bad news
there is basically no compression on bottom cylindre and the compression is bad on the top 2 as well......
what should i do ?
is it realistic to think i can fix this ??
