Sharing fresh water intake from one engine to a second engine
QBhoy
Go OEM all the way. I’ve got 1200 hours on an original impeller. Although that’s only over 8 years and 1180 of the hours were in the last 3 years. I also have a water pressure readout too though. An extreme example and due a change for sure…but to show a point.
You can't flow enough water with one alpha pump to cool two motors. PERIOD
The pump curve is barely able to keep up with one motor
Service the pumps regularly
In an emergency, limp back on one motor
JASinIL2006
Gen one or two?i just changed an oem out of my gen two after 6 years looked essentially new..
I looked at those impellers after Bondo recommended them some time back. The seemed pretty promising.
At the time, it looked like they only made them for Gen 1s. I haven't gone back to see if they make them for Gen 2s now.
Scott06
Gen 2 drive or gen one? One big improvement on gen 2 impeller vs gen one
