I have a 1964 Evinrude Big Twin 40HP (long shaft) that I'm tying to remove the lower unit. I removed the rear lower outer cover and then removed the long hidden bolt that goes top down. I removed the side plate and then the inner plate and then removed the shift linkage bolt. I removed all of the lower bolts and the lower unit is loose as well as the 5" long shaft adapter (short to long shaft). It looks like it should just drop but it's not. I looks like the shift linkage is hanging up. Just will not let go. Is there a trick to this??? Am I missing something?
Model # 40452 S
Serial # E01387
Thanks guys!
Model # 40452 S
Serial # E01387
Thanks guys!
