200 hp 90 degree powerhead, FITCH midsection
pastorbud
I have an aqua sport bow rider with a 25 inch transom. I bought a 200 hp Johnson 90° motor (J200VLSIF) with a 20 inch leg on it, which I want to mount on my 25 inch transom.
I’m hoping to pick up a 25 inch midsection and outdrive to put on the 200 horse Johnson.
I found a guy who is selling at 200 horse FICHT (E200FPXSSH) with a blown power head. That seems to happen a lot! 😜
So I’ve done a little online research and talked to the seller and we both think the 200 HP 90° block will go right onto the 25 inch midsection and outdrive from the 200 horse FITCH.
Is there something more I need to know? Does this sound workable?
The guy wants to sell the motor whole, so I guess I will have an extra trim tilt and a dead FITCH power head when I’m done. He wants $500 for the whole thing.
pastorbud
Gee, what happened to the carb Johnny 150HPV6 you had?
Heh... you got a good memory! I kinda got tired of messing around with it! This powerhead is newer and in better shape. I'll still try to get it running and re-sell it, or I'll put it on another hull.
stresspoint
look up the part number for the base gasket on both motors , if the gasket is the same there is a good chance that the power head will fit.
pastorbud
So the lower unit came of easy. Steering swivel too. But the exhaust housing seems to be stuck on there pretty good. I have removed all six of the long 3/8 bolts and six 1/4-20s. Smacked it a bunch of times with a plastic dead blow mallet. No luck. Any tips on getting it loose?
