Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
So over the weekend ended up gluing 3 pcs. of left over teak to finish the port side teak trim under the windows. Looking pretty good.
Also ordered a new remote controller for shifter. Will have to play with the wiring or get a harness adpt. to match to to the ole VRO.
The crazy is you can buy this from $500.00 to $167.00. Same darn thingy.
zool
So which one did u order ? :cool:
kcassells
kcassells
Perfectly all rain this weekend. I need to prep for winter interior work.
I recieved the remote unit and had to do some chop chop for the fit. No surprise though. Fitted unit for now. Issues to contend with are unit had to be brought back further from new dash to all clearance.
Next is too figa out how to make it purty. Still working on teak window trim.
Grab new remote cables, fit, install etc. Then move into the cuddy fabric and trim.
View attachment chop chop vid 3.MOV
kcassells
Done for the day. Pouring but able to work in the new shed. Sanding the teak to fit and making upper/lower with soft roll to fit better. 3 pcs. make up this 1 pc.
Go Eagles. Yea.
zool
Anyone ever use this material to template for fabric?
Good/bad,...? pros, cons
Has anyone used this pro/cons?
I used it for patterning the eva foam decking, its basically plastic with a string grid pattern in it. It lays well and is transparent for easy marking with a felt pen.
