350 mag mpi manifold/elbow temp
Scott06
I'll take the housing off and double check. Is there a gasket there that needs to be replaced or sealant? Or can I just take it off and put it back on?
What would be the best way to check the impeller output in the water?
Yes there is a gasket that will not survive taking apart- oem ones have a rivet in them to ensure continuity between housing and manifold so temp gauge works....
You can also pull the hoses off the outlet and look in the ports.
Merc has a flow test you do by taking water supply hose (from outdrive) off the thermostat housing and measure flow into a bucket - X seconds should = Y volume kind of thing. You probably can find it on line or if you have factory manuals it will be in there- cant remember if it is in drive or engine book.
Lou C
that's what I was referring to...the flow test...volume of water in x amount of time.
Searay205
So much guessing and wrong information. Your exhaust manifolds have temperature sensors in them and will alarm if get to hot. If you had a RInda then it would tell you the temperatures the exhaust manifolds are running that how I know mine. Cat manifolds run hotter than old style manifolds even with catalyst removed (great job!!!!). Your initial temps at idle are perfect. The temps you refer to coming off a plane are fine unless they never drop back down to what you said at idle. How long for temps to drop? are they still hot a week later sitting in your garage??????? Manifolds have ton of iron it takes time for them to cool back down. Your thermostat is 160F. At idle probably will never fully open. On a plane running 3500 rpms the engine will be at least 160F, thermostats control minimum temp not max. You will not be able to put your hands on your cat manifolds even without the cats coming off a plane. Your IR is probably cheap POS. You have to shoot the manifolds within an inch or you are taking the temperature over a 8" area. IR temp will only be correct if dull black as the emissivity defaults to one. In the end I don't think you have any problem at all. If it makes you feel better you can't hurt the manifolds they are beast, the catalyst elements are fragile POS, again great job eliminating!!!!!!
Lou C
However, I did think that Merc designed those manifolds to maintain a certain temp, because otherwise the cats would be too cool to work. Since not that many people have done this, there is not much information on it and I bet that is why Merc will not provide that information (temps) they don't want people removing the cats for obvious reasons.
